Can I just plug it in? | on ElectriciansForums
Discuss Can I just plug it in? in the UK Electrical Forum area at ElectriciansForums.net
UK
Hi, I have purchased a piece of equipment from China and we are required to finish the final wiring. They have supplied a length of 3 core 6m cable, which seems excessive.
The unit has a power consumption of 1kw - 2.5kw
Rated voltage - 220v
Rated power - 3.42kw
Rated current 20a
Would it be safe to wire this up with a 13 amp 3 pin plug or will this need to be hardwired.
Ideally we would like to be able to move the oven to various locations around the factory, so it would be preferable to use the 3 pin plug, so is there anything I could add to the oven to allow this?
20A at 220v is 4.4Kw
so all bets are off when it comes to figuring out what its requirements are.
I would suggest putting it into 32A rcbo as a temporary supply, turning on everything to full power and using a clamp meter to measure its current draw.
that should give you a good idea of what size supply it will need.
Reply to Can I just plug it in? in the UK Electrical Forum area at ElectriciansForums.net
My wife’s Evoque gets about 32 miles on a full charge and I get about 28 miles on my F-Pace. I don’t know how long a full charge takes but I...
The same socket can be used for different appliances, such as kettles... which will draw more than 5A The size of the cable determines how much...
