Can I move toilet waste pipe above decorative moulding outside front door Discussion Thread | on ElectriciansForums
Discuss Can I move toilet waste pipe above decorative moulding outside front door Discussion Thread in the Plumbers Forums area at ElectriciansForums.net
This is an RSS feed of thread: Can I move toilet waste pipe above decorative moulding outside front door
Content of the thread:
[ElectriciansForums.net] Can I move toilet waste pipe above decorative moulding outside front door Discussion Thread
Hi
I have a problem about waste pipe positioned over the front door
A bathroom was turned into a 3rd bedroom. The toilet and sink was moved to a storage room just behind the 3rd bedroom. The waste pipes were put under the floor. Everything works fine but the customer wants the waste pipe to be lifted above the decorative plaster .
I’ve been advised that is not possible as the waste needs to pass down to the soil pipe outside.
Can I move toilet waste pipe above decorative moulding outside front door to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Can I move toilet waste pipe above decorative moulding outside front door Discussion Thread in the Plumbers Forums area at ElectriciansForums.net
This is an RSS feed of thread: Obstructed pipe q can I Reposition toilet pipe Content of the thread: Hi I have a problem about waste pipe...
This is an RSS feed of thread: Waste pipes above ceiling in new extension Content of the thread: Hi guys I have expressed an opinion on this...
