Can I remove switch to leave circuit permanently on? | Page 2 | on ElectriciansForums
Discuss Can I remove switch to leave circuit permanently on? in the UK Electrical Forum area at ElectriciansForums.net
Wales
Hi,
I have recently moved in to a house where there is a switch outside the bathroom that controls the power to the shaver socket.
Never seen this before and every other shaver socket I have seen is permanently on.
Can I safely remove this switch so the power to the shaver socket is always on and if so how?
Ideally yes if its simple to do.
You can do this right now.
On thd shaver switch, move the brown wire at the top to the COM terminal at the bottom. You’ll end up with three browns in that terminal. They might fit.
That will make the shaver point always on. Then you can get a replacement 1G switch and move the wires across.
Obviously with the new switch you won’t need the link wire that goes from COM>COM.
Obviously with the we new switch you won’t need the link wire that goes from COM>COM.
Great, thanks for your help.
I will give it a go tomorrow. 👍
Reply to Can I remove switch to leave circuit permanently on? in the UK Electrical Forum area at ElectriciansForums.net
Hello Brianmoooore, Thanks for yor reply - Sorry that I did not see your message until today - the Forum replies notification emails about your...
Hi all, first post, please be gentle ;) Iv been involved in a bathroom refurb, nothing major, moving a light fitting and switch. My problem came...
