Gsk5676
Can anyone let me know if I can remove this recessed bracket? I recently had someone close off the wiring so I could patch up the hole but now it’s in the way when I go to put the drywall in.
Discuss Can I remove this recessed bracket? in the UK Electrical Forum area at ElectriciansForums.net
Go ahead and move it and just cover it upCan anyone let me know if I can remove this recessed bracket? I recently had someone close off the wiring so I could patch up the hole but now it’s in the way when I go to put the drywall in.
Install a junction box and install wire nuts on each cable.My concern is that there seems to be a cable end floating round, it would be better to see that terminated safely inside the junction box before covering it all up.
thoughts @Megawatt ??
sorry, can't give you a like for that. here we hate wire nuts. Wagos Rule .Install a junction box and install wire nuts on each cable.
Reply to Can I remove this recessed bracket? in the UK Electrical Forum area at ElectriciansForums.net
