Can i run led under cabinet lights off a ring circuit spur? | on ElectriciansForums
Discuss Can i run led under cabinet lights off a ring circuit spur? in the UK Electrical Forum area at ElectriciansForums.net
Carlisle
Hi
I'm fitting a new kitchen and as the light circuit isn't that easy to get to I want to fit a spur off 2 different sockets. My thoughts were to run a spur from each socket and fit a fused switch to feed low voltage led under cabinet lighting. 3 leds under each side. would this be acceptable or should it be done differently. Any advice would be appreciated?
Reply to Can i run led under cabinet lights off a ring circuit spur? in the UK Electrical Forum area at ElectriciansForums.net
Thanks for the advice.
Neutral and live
