Discuss Can I run spur from shaver point in bathroom? in the UK Electrical Forum area at ElectriciansForums.net
shaver points are generally fed from lighting circuit, so should be no problem.as buzz says, thought, the circuit must be RCD protected.Hi I have an illuminated bathroom cabinet that I want to put into the bathroom. Itās 240v . I only have a 240:110 shaver point, so I wondered if it is possible to connect the cabinet someways?
Yes circuit is RCD protected.Is the circuit RCD protected ?
Is the mirror going to be situated in a zone ?
Is the mirror suitable for zone if so ?
Will the circuit be tested for safety and the work reported to building control if required ?
Situated in en suite
Itās a manufactured bathroom cabinet/ mirror
If you read the connection instructions it will state which zones it can be installed in. This alteration should still be tested for safety once completed.Yes circuit is RCD protected.
Sorry g G or delay:What is the make and model number.
Reply to Can I run spur from shaver point in bathroom? in the UK Electrical Forum area at ElectriciansForums.net
