Can I swap a switch for a plug | on ElectriciansForums
Discuss Can I swap a switch for a plug in the The Welcome Forum area at ElectriciansForums.net
Henstridge
hi I have a fridge freeze that in wired into a switch that turns it on and off with no socket! Getting a new fridge delivered and instead off cutting the plug and trying to chase it up the wall and into the switch can I just change the switch for a single socket?
Many thanks
Have you oulled the fridge out to see how it connects? Normally a switch like that would control either a socket or a connection plate behind the applience or in an adjacent cupboard.
If it is actually wired directly into that switch then yes you could change it for a single socket. However, wiring directly into that switch and chasing the applience flex into the wall is a very strange, non standard way of doing it, and may suggest whoever did it didnt know what they were doing. So it may be worth having the rest of the kitchen wiring inspected and tested.
As already posted there'll be more than likely a socket already there. Top tip, if using this sort of set up don't use a switched socket, always a pain when you struggle to get the appliance in and the switch is off...
I’ve seen something similar where a 3/4 conduit was buried in the wall with a slight bend, leaving the end of the pipe exposed. The appliance flex was pushed up the pipe to what was a SFCU
Reply to Can I swap a switch for a plug in the The Welcome Forum area at ElectriciansForums.net
And fully tested it with an MFT obviously
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
