Can I use a 4mm T&E for a 7.5Kw shower? | Page 4 | on ElectriciansForums
Discuss Can I use a 4mm T&E for a 7.5Kw shower? in the UK Electrical Forum area at ElectriciansForums.net
I love these convos you have to put every detail in about every product or operation. The science behind it or the physics, the calculations like you designing an electrical installation right from your phone.
If you put anything in laymans terms someone is quick to point out a fall or bite ?
Have fun guys another forum i wont be on again.
You lot are way better electricians...well done
You been on something? This forum is a good mix of banter and good knowledge. If you have problems on here then god help you in society.
Stick around, you'll get used to us ?
A heating element takes the same power to heat up…. Be that a 2.5kW kettle or a 9kW shower…. Whether it’s cold or warm water going in, it’s stil 2.5 or 9 to heat it.
As before, it’s how much water. Either stored water, like a kettle. The less water, the quicker it takes to boil…. Or a shower, the faster the rate of water passing through.
An element is a constant resistance…. Supply voltage is constant…. So the power taken by the element is constant.
(Give or take a little change of resistance as it heats up)
Based on a 240V, 7.5kw shower and a total length of 16M of 4MM2 cable and assuming cable resistance at 4.3mohm/M then my (rusty) calcs give a current flow of 30.975ohms and a shower output of 7.368kw and a voltage drop of 2.13V through the cable resulting in a cable heat loss of 65.94watts or 4.12watts/meter of cable.
So is 4MM2 suitable??.
I agree a 100 per cent that the main reason a shower switch burns out is down to a loose terminal connection or cheap shower switch especially where we as sparks are cramming a 10mm cable into a 47mm pattress on the wall loosing them in the process.
However from my experience if your over-rate your cable from say a 9.5kw shower on a 6mm cable it can cause heat to dissipate anywhere on the cable. So where theres a big box on the wall full of single insulated cables with no heat to escape you see it travel all up the cable.
Some ive seen so bad the the whole cable has had to be replace. Simarily to where the cable has been bent or weakened through installation. Heat is going to affect the cable where it is most weak first so at joins or switches.
Still it takes a long time for a 9kw shower to cause the cable to burn up as its never running at full load most of the time.
Somebody recently wanted me to fit a shower switch shed bought from wickes...
It felt light, looked shyte and came complete with a 27mm surface box to mount it on...
I took one look at it and said: "nah....yer allrite love"
Went round the corner and got a decent one weighing twice as much and a 47mm box...
I don't know why people persist in going to these diy stores for electrical stuff...?
coz they know no better. i will only fit the crabtree or click 50A round jobbies. them square ones suck.
Reply to Can I use a 4mm T&E for a 7.5Kw shower? in the UK Electrical Forum area at ElectriciansForums.net
Thanks for your time and opinion.
Being pedantic, the Crabtree 50A cooker switch is a 4500/1, which has 'cooker' printed on it. For a shower, you require the 4500, which is the...
