Can I use an electric clothes iron to control a quartz heating element? | on ElectriciansForums
Discuss Can I use an electric clothes iron to control a quartz heating element? in the UK Electrical Forum area at ElectriciansForums.net
Welcome to the forum mate.
As above, we need more info.
A quick Google says that the temp of a clothes iron is between 180-220Âş C (356-428 Fahrenheit)
Is your quarts heating element within that range?
but can it cook cheesecake?
for the technical details of an iron , i need to consult a higher authority ,'er indoors. she's the one that takes it off the fire when it's hot enough.
Reply to Can I use an electric clothes iron to control a quartz heating element? in the UK Electrical Forum area at ElectriciansForums.net
G
Dual fuel towel rail heating element The instructions with the new dual fuel towel rail we've had installed are in very bad English and, anyway...
GonisDowr
G
As long as the heat input is greater than the heat losses from the container and the resistance is sufficient to limit the current to no more than...
davesparks
