can it be done , or bite the bullet and buy new stat ? | on ElectriciansForums
Discuss can it be done , or bite the bullet and buy new stat ? in the Central Heating Systems area at ElectriciansForums.net
stidge
Nottingham
Hi all. Worcester green star boiler with plug in timer/stat fitted. u floor zone added so plumber has installed 2 x 2port valves. My question is can I add the 2 valves and still use the pre fitted wireless stat or do I need ( as I think) to remove the plug in and fit a separate wireless stat for heating and obviously another stat for ufloor . looking at the terminals I don't think it can be done.
anyone have any experience of this or advice please ?
Hi stidge
In the current set up how do you control the hot water. Is there a valve that controls the original heating and hot water
The underfloor will need a new stat, it will need to be wired where the stat is controlled by the boiler when the boiler is working from the original stat, it is not going to be able to control the boiler with the existing stat in, it will only work if it is wired parellel with the existing stat, not sure that is easily possible with the original stat which is in the front of the boiler. If the original stat was connected to the boiler and remote it would be easily done.
wire it like any normal s plan but remove the onboard timer / stat as that will only run one zone also dont forget to pull the link out
but to do the above works depending on what Worcester boiler your going to need a gas safe engy with you
So your plumber has added the 2 x 2 port valves to control the current heating and the under floor heating. Your problem will be how do you control the valve for the current heating. You will need a feed to power the valve and a switch live to the valve to tell it to open. This would have to come from the plug in timer/stat. I wolud be tempted to put a programmable stat in (could be wireless if you wanted) to control current heating, and a control centre to wire everything to including the boiler
Thought as much mate , I will remove plug in and fit two separate stats for the two valves ! Cheers
that will work, just parallel up the switch wires
Reply to can it be done , or bite the bullet and buy new stat ? in the Central Heating Systems area at ElectriciansForums.net
The 4 pumps are :- 1. boiler to cylinder 2. C/H and UFH circulating pump 3. UFH dedicated pump after manifold 4. DHW circulating pump. (this just...
I think that's the point I was trying to illustrate. If volt free contacts on a device on one supply are switching mains voltage coming from...
