Can one 15 amp lead run two 15 amp power points | on ElectriciansForums
Discuss Can one 15 amp lead run two 15 amp power points in the UK Electrical Forum area at ElectriciansForums.net
Malcom
Australia
Running from house to a van home to power van there is two 15 amp points .I was hoping to run from a single power point a 15 amp lead with a double plug 15 amp extension lead..Will I need a 30 amp lead or will i require a electrician to install something at the main box from my house
Reply to Can one 15 amp lead run two 15 amp power points in the UK Electrical Forum area at ElectriciansForums.net
So this was resolved. I used a line tester to see if I had power across the breaker on the main box in the house. Breaker tested fine. Then I...
Yes you will need to install # 4 wiring times 4 for your 2 hots, 1 neutral and 1 equipment ground. As for keeping the grounds and neutrals...
