J
joeyscurlock
I really should know this but any help would be great! A customer wants me to put some outside lights up. An existing light with a built in pir which will switch on 2 halogen lights further down his garden. Then one light at the bottom with a pir built in which will also switch everything on. Big garden and one pir won't cover everywhere. If I take a main (L,N,E)to first light. 4 core armoured out connect switched live, N and E through the two halogen lights and just leave the common to flow down to the pir at the bottom without connecting to the halogens so the bottom pir light has got a permanent live to work as a pir so connect switched, permanent, N and E in first pir light and bottom pir light. Would that work?
