can Wires run through a spur | on ElectriciansForums
Discuss can Wires run through a spur in the UK Electrical Forum area at ElectriciansForums.net
Ell704
Cardiff
Can I run 2.5mm and 1.5mm in the same chase going down to a 3amp spur with the 2.5mm just passing through the spur to get to the sockets.
  • [ElectriciansForums.net] can Wires run through a spur
Reply to can Wires run through a spur in the UK Electrical Forum area at ElectriciansForums.net
😄 It wasn't the worst I seen over the weekend. Took the kids to Cumbria zoo whilst over there, and the toilets by the giraffes just had twin...
It can be easy to lose the sequence of things. If the fused spur has a neon indicator and this isn’t coming on then I wonder if -the original...
