P
pipunch
Quick one.
Tails are 10mm. Earthing cable from rod to earthing block inside the CU is 16mm.
Where i am, we have the tails in, everything RCB protected and then the earthing cables from the circuits/appliances etc into the earthing block. On my CU, the earthing block is a bank of 'quick connection' terminals that take 1.5-2.5mm cables, and then right next to them, we have a small bank which takes up to 16mm.
The spark at the wholesalers has just told me that with my grounding rod (you have to do it yourself here, not the responsibility of EDF) i have to use 25mm bare copper from the rod to the exterior 'barrette de coupure' which goes on the exterior wall and connects the 25mm bare copper to 16mm shielded earthing cable.
So everything will go:
Rod -> 25mm bare copper -> connection barrette -> 16mm earthing cable -> earthing bank inside CU -> earth cables out into circuits/appliances etc.
Just checking there is no reason, theoretically, that i can't use 16mm earthing with a 10mm supply.
Oh, and one more thing, the bank on the earthing block which has the 16mm terminals has '14mm ---->' written on it with the arrow pointing at the bank of quick connection terminals. Any idea what this means/is ?
This is my last step before i call my electrician in to condemn/redo/ok my work.
Thanks.
Thanks.
