Can you fit Surface mounted metal clad boxes in a commercial kitchen? | on ElectriciansForums
Discuss Can you fit Surface mounted metal clad boxes in a commercial kitchen? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
sparkysean
hi im just wondering if your allowed to fit metal clad surfaced mounted boxes in a commercial kitchen.
Interesting question.
I've never thought about it before. They aren't the prettiest of surface mounted accessories. I hate the back boxes on these as they usually have many mounting hole positions which may need sealing in an environment open to moisture which may run down walls.
Also, I take it that it'll be conduit cable management for which they're suited and not square-line mini-trunking with dollops of white silicone filling gaps around square pegs in round holes.
Lets see the replies from the experienced guys.
Regards
s.f
Cant see that it makes a lot of difference to being a flush mounted socket in a kitchen, would advise the sockets are RCD protected for obvious reasons and I guess a squirt of silicon between the backbox and wall.
You see sockets like this in many a kitchen so I dont really see a problem, Obviously keep away from water but kitchens do need power.
Its not a problem as far as regs go. I have done it many times with no issues. Used 2.5 T+E into steel conduit into metal clad surface box. Job done. They are no more dangerous than any other socket.
Reply to Can you fit Surface mounted metal clad boxes in a commercial kitchen? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
https://www.d-line-it.com/u-clips/
2 3
