THIS IS FOR ELECTRICAL NEWS ONLY
Discuss Can you put a 32amp fuse spur off of a socket for an electric shower or does it have to go through consumer box? in the UK Electrical Forum area at ElectriciansForums.net
Its 7.5kw so guessing 32amps i know 8.5 9.5 are 40 but wasnt sure on 7.5. Its just to install.in caravan so got 3amp ligh circuit and 32 amp ring main didnt really wanna add a new consumet unitDirect from consumer unit, and most electric showers are rated at more than 32A
Oh really thanks il have a check as was a bit confused as usually 100amp off a main board spitting off in a conumer box but coudlnt work out where it was going lolFrom experience...
there may be a 32A in the board, but you have to check the supply coming into the caravan. Possibly only 16A
Good shout. Though touring caravan or static caravan?From experience...
Its static its got a mains electic supply but only basic consumer box in van. Ive run another 2 seperate ciruits to shed for lights and sockets just wasnt sure how easy changing consumer box would be for shower as no free spots. Guess its time to get an electrician hahaGood shout. Though touring caravan or static caravan?
If touring and it's on a UK camp site - definitely 16A supply. If you are using a 3pin plug to 16A converter at home then it's on a 13A supply. Both are sadly unsuitable for that shower.
A static caravan could have any supply though!
Can see why they done it as logically it should be that simple but nothing is ever that simple think il just get it all in place and get an electrician in. Thanks for replyWe had that exact situation when I ran a site... A customer had her bathroom all done by a family member, with electric shower... no one thought to ask an electrician! They just stuck a 40A into the board, wired it in 6.00mm and never looked at the cable supplying the board.
you’re right in saying that a static could, in theory have any size of supply.... up to the 100A isolator fitted in the board... but 16 is normal.
No thank you.it's time to change the shower for one run off the gas boiler. that way the boiler heats the water, not the electrical supply, which is woefully inadequate for that.
why not?No thank you.
Reply to Can you put a 32amp fuse spur off of a socket for an electric shower or does it have to go through consumer box? in the UK Electrical Forum area at ElectriciansForums.net
