Can you tell the Kilowatt wiring capability from just looking at the CU? | on ElectriciansForums
Discuss Can you tell the Kilowatt wiring capability from just looking at the CU? in the UK Electrical Forum area at ElectriciansForums.net
cable_guy
Hi all,
please allow me to prefix this post that I am not an electrician. I come here only for advice in advance of getting a professional to do the work on my behalf.
I currently have a gas oven and wish to replace it with an electric one. I want to understand if the electric supplied to my current oven is sufficient for an electric oven, and the only thing I have to go on (as a non-techy) is the switch which is a "seperate" (big fat red) switch for the oven on the wall, and the CU which has the following (far left).
http://i.Upload the image directly to the thread.com/PGVSRUk.jpg
Is this evidence enough to prove the capability of the wiring? or would I need to get a sparky out to check the thickness of the wire/something else please?
thanks in advance.
If you have a gas hob then what you have already should be more that enough to supply your electric oven , as long as the cooker supply was wired correctly in the first place it will be quite easy for a spark to connect the oven up for you .
experienced electricians can tell the capacity of a wire by just looking at the size of the wire.
So yes you can tell the kw of a wire by looking at it
but with a 32A breaker I would guess it is 4mm cable.
Have you got the lottery numbers for next week?
Based on the size of the circuit breaker at 32A then yes if all is correct the cooker outlet should easily deliver 13A
However that assumes the wire used to connect from the circuit breaker to the cooker outlet is correctly installed and the appropriate thickness (4mm 6mm etc as the cross sectional area of the copper cores not the thickness of the cable externally)
So to be sure and safe an electricians eye is needed.
Reply to Can you tell the Kilowatt wiring capability from just looking at the CU? in the UK Electrical Forum area at ElectriciansForums.net
How did it go?
Hi Mainline and thanks for the reply. My inverter is only fed from the mains supply over a 4 hour period at night and it does not have any tie...
