Can you wire two Pyros into one socket?
it's a socket to put a bobble in.
Thanks Tel, tell me where can I get a Bobble, do CEF stock them, or is it an orange shed type item? can't think what the Guy behind the counter would say if I asked for a box of Bobbles to fit the new Bobble socket in my House.
Hope the OP isn't offended, cus it's banter, nothing more nothing less.
It is probably a ring final circuit so both need connection. You are going to need to knock out the wall below to access the glands to ensure they are very tight as the cable sheath provides the earth. I would seriously consider using an experienced electrician to do that and not some wet behind the ears youngster.
oi! i know what u mean though, only time i really worked with pyro is at college
i can only find bobble borats
What about disconnecting the spur then using a single to double socket converter over the MICC socket and filling the remains of the other single socket?
You would need to ascertain the integrity and the method of how the original SPUR was installed. is it part of the RFC or a spur from a spur, not as simple as imagine Davisonp
The folk who used to install MICC in general used to do things properly, so in this setup there was a single back box with two MICC into it, an someone wanted a second socket, so spurred off the MICC socket putting a second back box next to the original. Confirming the original MICC install should be straightforward, and not disturbing the original MICC back box preferable to messing with the buried cables, hence to tidy things up, a socket converter giving two sockets from a single back box and fill or remove and fill the spurred back box. Still a job for a proper electrician.
good luck with that
Davisonp: Thats food for thought, Ill tell my sparkie but Im still tempted to do it myself lol. I won't though, as you've said, the back box and milled nuts are ruined. I could be in a world of pain very quickly!
This youngster has rewired a lighting circuit in a church using Pyro, were all not complete tarts i will have you know.
Last time i worked with Pyro was when a builder put an angle grinder through a 10mm 2 core submain in a empty flat.
Bloody thing was imperial it cost about £200 for the tools and gland that I needed to order to re- terminate it, I had to solder the pot on too as it was obsolete and didnt quite fit.
The stuff is so expensive now, personally wouldnt want to touch it unless I had the tools to hand.
Another issue is that they are probably imperial cables and a new back box will have metric entries which will be oversized and hence you lose an effective connection between the gland and back box which you do not want.
You could be right W, not sure. If it's push on neoprene, it's metric. The imperial discs I remember didn't have it. The sleeves were lipped and pushed through holes in the disc from the inside of the pot before sealing.
Both types of disc and sleeve are still available, if I remember correctly the lipped type of sleeve is a higher temp deal than the standard stub cap type.
SFHD,
mossep,
