Cannot find any Type B's Please point me in right direction.. | on ElectriciansForums
Discuss Cannot find any Type B's Please point me in right direction.. in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
fareham
I have already gone over the whole Rcd situation as many of you have also probably seen numerous threads. My problem is i cannot find any Type B rcd's anywhere!
I have installed A TL inverter. At the moment cable is buried but if i can even find a 100mA i will re-route the cable to avoid the 30mA.
I have MCS assessment next week and i cant connect the mains up until i find an rcd, I have called every wholesaler and trawled the web to no avail,
Please if anyone knows where i can get my hands on one point me in the right direction!?
Im never using TL inverters again if getting the Rcd's are this much trouble!!
Many thanks
Silbert Solar - Andy 0'Leary - 0[FONT=&quot]1252 815518[/FONT]
Depending on the make and model of the inverter a Type A 100ma might be OK.
At the risk of labouring the point, if you re-route to avoid the need for a 30mA rcd, then you are unlikely to need any rcd at all, so the problem goes away.
Lol, Doepke are actually a very high quality manufacturer, based in Germany. You might be surprised at the number of brands out there that are actually made and badged by Doepke, especially RCDs. Specifically for Type-B design, Doepke and Siemens are the only 2 manufacturers globally who have the history and patents relative to the design and functionality of the device.
Hi,
I had the same issue with a "TL" Inverter.
After doing some research and making enless phone calls I was told the 100 mA Rcd was only due to nuisance tripping. after then fitting a garge unit istill had the issue of the Rcd tripping out which again was nuisance tripping.
After some more investigation and more time trying to get through on various help lones, I was told the make of garage unit I had installed would still trip on a 30 mA Rcd and to try MK.
Half a day later, new MK garage Db was installed with 30mA rcd / Main switch and hey presto....... everything works fine.
Pity it took so long and it was quite costly to find all this out but we got there in the end.
Ian
Im finding this thread scarey Scarey YOU actualy take money off people but dont know what/why your fitting
just fit new consumerunit n thats fine OMFG
Reply to Cannot find any Type B's Please point me in right direction.. in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Protection from what? What kind of problem with the inverter is going to be helped by having an RCD on the circuit?
davesparks
"A catalogue of errors" would be the appropriate phrase here and I agree with Avo and James that HSE need to be involved rather than this forum...
