Can't find Lighting Transformer | on ElectriciansForums
Discuss Can't find Lighting Transformer in the The Welcome Forum area at ElectriciansForums.net
Electron
Altrincham, Cheshire
Just been on a "simple" job, changing 8 50w MR16 halogen downlights to (customer supplied) IKEA LED's (ÂŁ3 each!).
Pulled out the 150W transformer that supplied the first set of 4 and changed these. The other transformer must be fixed into the ceiling void. I can't feel it and the void is full of rockwall insulation. Has anyone any ideas how to locate and remove the transformer without taking the ceiling down?
As per Tel - sometimes there is a section of flooring above that's been taken up in the past to install the transformer. Murphy's Law is it's now under the bathroom tiles.
I hope the existing transformers are compatible with LED's. I've had experience with identical transformers where some LED's worked and others didn't. Had to change every trans for a driver over time.
Unlikely that the tranny is screwed down. Possibly just clips in the T&E supplying it
I spent a couple of hours a couple of weeks back pulling an landing floor apart to locate 2 x transformers ......... customer not too happy
I'm going back next week to remove the transformers and re-run cables and convert the MR12 to GU10 LED's
My Top Tip for the OP - don't let customers buy products like that ..... or don't agree to fit them.....
It probably is being held by clipped T&E although the transformer I removed has two screws for fixing to a joist. If, as seems likely, the lost transformer is the same type there is the possibility it has been fixed.
I think I will take the supply from the point it was attached to the transformer I removed and put new cable to bypass the lost transformer.
Reply to Can't find Lighting Transformer in the The Welcome Forum area at ElectriciansForums.net
For my hapeneth and learnt from hard recent experience, the term LED transformer and driver tend to be used interchangeably, when they are...
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
