Capacitor equation | on ElectriciansForums
Discuss Capacitor equation in the Australia area at ElectriciansForums.net
J
jimmyjazz
Can anyone help with this college equation?
3 x capacitors in parallel - 10pF (To the power of -12), 15 uF (-6), 25 nF (-9). What does Ct = ? Tutor says 10 (-6), I think 10 (-14).
Thanks:confused:
Capacitors in series - just add them all together.
Capacitors in parallel - 1/[(1/a)+(1/b)+(1/c)......]
Would make your total to be ~ 15uF.
Or more exact 15.025010 uF
That should be the other way around.
Capacitors in series = 1 Ă· ((1 Ă· a) + (1 Ă· b) + (1 Ă· c)......)
Capacitors in parallel = Add them all together.
Although your answer is correct.
[10 x 10^(-12)] + [15 x 10^(-6)] + [25 x 10^(-9)] = 15.02501uF
Reply to Capacitor equation in the Australia area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
Hi There How did you get on with your basement project?
