motor runs fine if i give it a push. i assume the cap in the pic is a dual start/run. only shows 1 value (4mfd) so does that mean it's 2 x 4mfd caps in the one can? assuming that.best place to get one?
Discuss Capacitor Fail?????20 bloody characters. in the UK Electrical Forum area at ElectriciansForums.net
cheers. yous a star.
don't get big-headed though. your doors are only 2'6" wide.(that's 900 millipedes for the younger plebs).That's me.... Quite good for an un-qualified guy...
yeah, yeah. too late to edit. should be 750mm or thereabouts. bloody french dimensions. so confusing. just because they can only multiply by 10.Think you might need to recalculate that mate.
dunno.might just be a start cap. will know more when replacement has gone in.Hi bud,are those capacitor terminals not paired?
motorised curtains. on a timer.when the control unit gets 240V motor runs 1 way. removal of the 240V sends motor other way. in either case motor runs if given a nudge but won.t start on it's own.Looks like a regular run cap for a PSC motor. If there's no centrifugal switch or relay, there can't be a start cap, which would usually be more than 4ÎĽF. What's the application?
Reply to Capacitor Fail?????20 bloody characters. in the UK Electrical Forum area at ElectriciansForums.net
