T
Tidy Max
hi folks, today ive found myself at a job where there is a humming on a sound system.
The humming is coming from a mic line that has 4 mics on it wired in series and the line is left open, each mic has a switch which switches in the mic capsule.
I think the hum is rfi, i have tried a resistor across the end of the line to close the mic line but it has made no difference.
My question is, what capacitor do i need to stop the rfi, there is an abundance of flurries through the building which i assume is the issue. I know assuming is dangerous.
Ive googled this topic and the general answer is 4700pf, which is for a type x use (between hot and cold).
Any help would be much appreciated!
Max
Sent from my GT-I9300 using Tapatalk 2
Max
