capacitors | on ElectriciansForums
Discuss capacitors in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Depends on what type, on electrolytic types and using a AVO (analogue meter) when you connect the probes to the capacitor, the needle used to flick to the other end of the scale and gradually return to zero as it was discharging through the AVO, other than that some DVM's have a capactiance function.
Reply to capacitors in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thank you, I'll give it a try 😊
"A catalogue of errors" would be the appropriate phrase here and I agree with Avo and James that HSE need to be involved rather than this forum...
