Capped F downlights | on ElectriciansForums
Discuss Capped F downlights in the Australia area at ElectriciansForums.net
F type are fire rated as you have said and this is to replace the fire block in the ceiling after you have cut the hole ,Capped F is a down lighter that can be covered in insulation, i did get some for a job just cant remember where from ,but havent seen them sinceHave alook in here Page 14 article on down lighters and shows the capped F logo
Yes its capped F I am after
Reply to Capped F downlights in the Australia area at ElectriciansForums.net
Neutral and live
If you have a plan for the downlights, and all you are doing is cutting out and fitting them then yes, 8 downlights in 4 hrs is slow. Fixed price...
