Capped gas pipe begging oven plumbing advice | on ElectriciansForums
  • Thread starter Steveuk
  • Start date
  • Replies 0
  • Views 74
Discuss Capped gas pipe begging oven plumbing advice in the Plumbers Forums area at ElectriciansForums.net
Capped gas pipe begging oven Hi all. Hope you are well.
So I fitted a new induction hob today for my father and whilst the old hob was off I saw that the old gas pipe for an old gas hob that has been capped off with a solder fixing is touching the back of the oven housing. I pulled that oven out slightly and it is not pushing the pipe much, like 1mm, but just wanted to check if you think it's ok to be touching the back of the oven? I mean it's not going to get hot enough to mess with the solder joint is it?
Thanks in advance.
Capped gas pipe begging oven to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Capped gas pipe begging oven plumbing advice in the Plumbers Forums area at ElectriciansForums.net
Commercial gas engineer poole At SCD Plumbing, we offer Commercial Plumbing Bournemouth, Commercial Plumbing Poole and a Gas Engineer Bournemouth...
scdplumbing
A
Blocked pipe Hi, ive got a blocked pipe from my basin/washing machine. Its old style pipe, the blockage is about half way down the pipe . Its old...
Andrew74
A
