C
Clucky
Hello everybody - I hoping someone can help. Just ordered some cables for a re-wire on a small semi, (1mm for lights, 2.5mm for sockets) and I need to get some capping. The rooms will be plastered so I'm going for the metal ones. My question is, what width should I buy for that size cable and do I need two pieces per fitting (i.e. one for each individual run of cable) or do both cables go in one?
Don't worry - I'm not fitting it just buying the parts
Thank you!
Thank you!
