I
Inx
Hi guys, first post just came across this forum so thought id ask the pro's before pulling my hair out even more..
Anyway, I pulled onto my driveway and all of a sudden my music just turned off, I look down to see my headunit has powered off and refuses to turn back on. When i took the face off the red light is flashing so there is power going to it?
I then noticed my clock backlight went off and I was also unable to change the time. Finally I realised that my dashboard was very delayed (about 10-15 seconds) when i turned on my engine, the needles would normally shoot up straight away.
I am almost certain these 3 faults are linked. My friend who is a student electrician had a look and assumed it was the fuses or relays, he proceeded to check and change but it seemed that was not the problem. He now beleives there was a short but is unable to locate where.
If anybody knows what this might be I would really appreciate some feedback because i recently spent alot of money on my sound sytem and im unable to use it.
p.s. I did change my headunit and the same happens, power is going to it but it will not display anything nor play any music.
