Caravan Site Help | on ElectriciansForums
Discuss Caravan Site Help in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Sparkypaul11
Hi all
I am quoting tomorrow to install some meters on a caravan site (x18). Is this work Part P notifiable??
I am unsure where the supply is taken from as have never been to this site so different scenarios would be helpfull to me.
Also what certification would be required EIC or just a MW for either replacing a meter or installing a new meter to the existing supply?
Regards
Paul
Reply to Caravan Site Help in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I hope this is not a trend by our energy companies....... a 200KVA supply is pretty standard for larger commercial . Are you sure you are talking...
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
