B
bisketuk
Been sat in the spare room for nearly 6months now, to say no longer needed wouldnt be right because it has never been needed.
As in the title brand new in the box with manual, still has the plasic cover on the plugtop.
These are selling on fleabay new for between £900 & £1100 from what i can see so i think £700 is a fair asking price.
07719 051 330 or pm me
Item location Swindon, Wiltshire. But i travel all over
Spec :-
Spec :-
- Liquid and vapour recovery with automatic changeover
- Self discharging and Hot Gas/Cool Gas discharge switch
- Suitable for all CFC, HCFC, HFC, and HC refrigerants used ondomestic, commercial and automotive refrigeration and air conditioning equipment
- Onboard refrigerant storage capability
- High efficiency heat exchanger and inlet oil separator with drain facility and integral mesh strainer
- Automatic high and low pressure safety switches with illuminated indicators and manual low pressure override switch
- Compressor fan cooling and compact air cooled condenser
- High electrical specification with encapsulated components
- Supplied with ball valve hoses
- 2m hard wired mains lead with moulded plug
- No maintenance required
- Overall Dimensions :
Length 470mm
Width 235mm
Height 335mm
Weight 21 kg
Refrigerants R12, R22, R134A, R404A, R407C, R410A,
R413A, R417A, R502, R600A, R290
Recovery Capacity up to 32kg/h
Onboard Storage Capacity 250g
Ambient Temperature Rating 50°C
Power Absorbed 145W
Running Current 1.3A
Voltage 230v
Compressor protection HP switch, thermal
overload
Inlet connection ¼" SAE male flare
Discharge connection ¼" SAE male flare
Oil Drain Connection ¼" SAE male flare
