cartridge fuse board inspection | on ElectriciansForums
Discuss cartridge fuse board inspection in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
P
Phantasmagoric
on a 3 phase cartridge d/b on the test will ity fail to 17th regs because you cant isolate all phases in 1 go. any one now :)
Isolate what?, if it's office power& lighting it'll be on 1 phase or split over seperate phases then pull the appropriate fuse(s) , any 3 phase equipment will have local isolation, any single phase equipment will have local isolation.
when i said isolate i mean isolate a 3 phase car lift from the board its got an isolater next to it but i thought 17th regs said you need to isolate all phases at same time is that just the isolater
All you need is to be able to isolate all the phases at one go which is what the isolator does. No need to pull the fuses if you are working on the lift, if you need to replace the isolator however, you will need to remove the fuses and put them in your pocket
I would do the same as Eddie except I would remove as much load as possible before switching of the isolator
Reply to cartridge fuse board inspection in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Adding a led strip isn't going to make much difference to the 3 phase balance. No real difference to where a 3 phase machine uses one phase to...
