B
bigd
Just a bit of advice from you guys.
Seem to be coming across these a lot recently in old houses-cast iron main fuse on the DNO side, prior to the meter. Told customers to approach DNO and get them to replace.
Does anyone know if the DNO's are charging for this service?
The last one I went to the cables from the supplier can't be more than 10-12mm, which feed into the meter. There's fuses in both the line & neutral and they're ceramic fuse carriers?!
How old are these? I've been informed that removing the ceramic fuse carriers is not a good idea as it can cause wear on the copper contacts, leading to connection problems. Is this true?
Sorry don't have any pictures.
