Cat5, 5e, or Cat6 cable for BT, network and future expansion? | on ElectriciansForums
Discuss Cat5, 5e, or Cat6 cable for BT, network and future expansion? in the Computer and Networking Forum area at ElectriciansForums.net
U
ugetwhatupayfor
Hi,
Have a full rewire coming up. Will also be cabling for satellite/tv around the house. Additionally, would like to drop cat5 (or should this be cat5e, or cat6?) to every room for future use:- phone lines, computer network and HDMI spring to mind. The latter will, I think, require some additional equipment such as a sender and receiver.
The cat cable would be run to a central location where I believe I will need a 'patch panel' (although I have no idea what this is, or how it works!). Presumably, I would need to bring in the BT line from the master socket and then connect in star formation (via patch panel) to a cat cable drop in every room that requires a phone line. Should I also drop an extra two cat cables to each room for future expansion.
Any guidance would be greatly appreciated.
AP
IMO cat5e is adequate. and reasonably priced . you would have a patch panel at the router/hub location, to which you would connect your cat5e cables.
Reply to Cat5, 5e, or Cat6 cable for BT, network and future expansion? in the Computer and Networking Forum area at ElectriciansForums.net
