Cat6 on Cat5e equipment | on ElectriciansForums
Discuss Cat6 on Cat5e equipment in the Computer and Networking Forum area at ElectriciansForums.net
The difference between Cat 5e & Cat 6 cable isn't anything to do with shields. You can get Cat5e/Cat6 shielded (FTP) and unshielded (UTP). Basically Cat 6 is a higher spec cable and is able to support 10 Gigabit Ethernet (10000Mbps) as opposed to Cat5e which supports Gigabit Ethernet (1000Mbps).
To answer the original question, yes you can terminate Cat6 onto Cat5e terminations/panels but of course it will only support gigabit ethernet speeds.
HTH​
The difference between Cat 5e & Cat 6 cable isn't anything to do with shields. You can get Cat5e/Cat6 shielded (FTP) and unshielded (UTP). Basically Cat 6 is a higher spec cable and is able to support 10 Gigabit Ethernet (10000Mbps) as opposed to Cat5e which supports Gigabit Ethernet (1000Mbps).​
More precisely, Cat5 is rated at 100 MHz and Cat6 at 250 MHz.
I would warn that as Cat6 has slightly thicker cores, you may find that punching it into the back of a Cat5e patch panel is problematic, although I've only really found this the other way around, i.e. trying to punch Cat5e into Cat6 slots, as they're designed for the thicker cores and so the Cat5e cores can remain loose after punch-down and in some cases fall out.​
You can put full 1080P + audio + IR down a single cat5e
Make that full 1080p Deep Colour + Full HD Audio + two-way IR + RS232 or USB + 100baseT Ethernet + 100 W of power! - HDbaseT over single Cat5e, is that "Video Application" enough for ya?
Who in their right mind specs Cat7???
To be honest I often use Cat6 just because it's physically more robust so will withstand more abuse, not because of any bandwidth reasons.
Yes, but can you put a satellite or cable coax down Cat5e? And what about 4k TV (launching at a trade show near you now)... There is always something pushing the bandwidth requirements further and further out.
General advice, always go for the highest specification you (or your customers budget) can afford at the time.
Full support for 48bit Deep Colour and 4k resolution applications (4 times standard HD quality) yes over cat5e.
But 4k is around 2-3 years way unless you have lots of ÂŁÂŁÂŁ
I'd argue that that advice is poor. The cost/benefit equation for Cat7 certainly doesn't stack up now, and there's no evidence that it will in the next decade either. Budgets, however large, are never limitless and there are so many other things that a customer could spend their money on that DO give a benefit right now.
Reply to Cat6 on Cat5e equipment in the Computer and Networking Forum area at ElectriciansForums.net
np I still have that spool to eventually get round to running a line outside Main challenge is doing it neatly haha
Nail as a fuse works until it doesn't. When you say certain areas what does that mean? If you have been doing it like this for 4 years why the...
