M
monte
Hiya All
I am wiring my house using CAT 6 Ethernet cable and bought outdoor grade CAT 6 cable as some of my runs will be outdoor. The problem is that outdoor grade CAT 6 cable is not very flexible by design - due to the black external layer, the white inner sheaf and the gel filled interior.
I have used the outdoor cable indoors as didnt realise the flexibility would be an issue. However the outdoor cable runs would still have the same problem.
My problem is in the termination. I am terminating into CAT 6 Euro Modules (made by Lap and suplied by Screwfix) that mount into back boxes in the wall. The problem is that the cable is not flexible enough to route into the back box and easily bend to the modules for termination. I have 4 Euro Modules per back box (ie double 240 V socket size).
The modules have cable tie fixing points to secure the cable just prior to the terminations. I have had to strip the two outer protective layers as the cable enters the back box for about 5 cm which is enough to provide some flexibility and get the cable to the module. There is then about a centimeter of cable with both protective layers intact which is where I cable tie the cable to the Euro Module. Then the protective layers have been removed to allow the twisted pairs to be terminated.
I see on various forums that it is not good to use cable ties or to strip the protective layers away for flexibility like I have.
My question is how are you expected to terminate an unflexible CAT6 cable into Euro modules in a back box?
I assume you can only do it the way I have but how badly will this affect data speeds?
It is a lot of trouble to setup a couple of PC's and transfer data to check the speed.
Many thanks in advance.
