category 1 failure | on ElectriciansForums
Discuss category 1 failure in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
dave-gardiner
can i wire from a 16A mcb to a 40A 30mA rcd then to a socket outlet( 13A) in 2.5mm twin and earth. or is the rcd to large.
as lenny says, but you can use a 40A RCD, the 40A is just the max. rated currentcapacity of the RCD, bear in mind it's not an overload device.
Reply to category 1 failure in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Tech has totally complicated 'control' Customer wants something controlling. First job is to figure out the best method
    • Funny
Depends how it is connected, which is of course a practical issue, the terminals are usually designed for 6/10mm cable so if you can ensure the...
