sirocco
I have a single story building and need to run a cable for outside lighting on a patio from a feed in the roof/fascia area.
The most direct route would be down via the external cavity wall (2.5M run length in the cavity) which has full fill rockwall insulation (100mm thick). I am intending to use 2.5mm NYY-J cable which is RCD protected.
Is running in a cavity an absolute "no no" or is just not advisable under the 17th edition regs?
