CCC of 2.5HR flex | on ElectriciansForums
Discuss CCC of 2.5HR flex in the UK Electrical Forum area at ElectriciansForums.net
sythai
Devon, United Kingdom
Can someone out there please advise if poss thank you.
Just looking at table 4F2A in in regs, but no figure shown for 2.5mm.
Any idea where I may find this?
Cheers Sy
I think,because of the vast range of flexibles,the manufacturer of the specific cable,would be the place to start. Fixed cables are fewer in type and conform to standards requiring different restrictions. The fact that cables for hand held machines,for example,are subject to a greater variance of external influences,affects their appropriate CCC. Some super flexible cables i have used in the past,have had a far lower rating,by the manufacturer,than the CSA would have suggested,eg;Medical equipment. This,is probably to prevent extra "electrical stress" being placed on a cable that may be subject to lots of other stresses.Or,ignore that,and if it melts...use a bigger one:bow:
Reply to CCC of 2.5HR flex in the UK Electrical Forum area at ElectriciansForums.net
Could you not make something? For example a thin metal sheet (aluminium for ease of working) a bit bigger than the hole (say 180 x 120 mm), with a...
In the current book (18th, amendment 2) it is under regs 433.2 and 434.2 In most domestic situations the usual approach is the whole circuit is...
