CCC of old stranded wires | on ElectriciansForums
Discuss CCC of old stranded wires in the UK Electrical Forum area at ElectriciansForums.net
Exeter area
Is there a CCC comparison table for old stranded wires anywhere?
I have a domestic installation, about 40 - 50 years old I wd say, and there are only 4 circuits, one is the sockets, with 2 wires into a 3036 30A fuse. I assumed it was a ring but it isnt, its not connected. The break is between the kitchen and rest of the house and theres been a kitchen conversion done, so Im assuming the fitter has bodged the wiring in a junction box somewhere. But is it possible its 2 radials, 1 for kitchen and 1 for the rest? The wire is 7 strand silver colour, so aluminium? but elsewhere in sockets there is a mixture of stranded and solid red and black.
I havent got the means currently to measure each strand (im going to get a micrometer, any suggestions from where?) but the overall wire size compared to a solid 2.5mm does look bigger.
The customer has had no fuse blowing problems (there again he probably wouldnt) but I told him it looks like the ring has been broken and needs re-connecting but I need to check...
The largest R1R2 reading on the circuit is 0.72 ohm and the largest Zs is 1.09.. phew! Ive fitted a dual rcd box, put the two socket wires into one 32A fuse as before temporarily and there are no problems on test results, apart from obviously no ring. No signs of charring at wire terminations either..
and what are the CCCs of these two sizes please? or is there a table somewhere?
Saw one somewhere but can't recall where, the 7/029 relates to 7 strands 0f Cu wire .029 inch in dia think thats the correct description as foe ccc about 30A used in rings in those days, thinks this may help
http://www.electriciansforums.co.uk/newattachment.php?do=assetmanager&values[p]=1140791&editpost=1&contenttypeid=1&poststarttime=1446112060&posthash=ba0ec9a3cfca6a5d97d396a2330f98e3&insertinline=1
Sorry can't send the PDF for some reason Comparison of imperial and metric conductor sizes, google DAE comparison of metric and imperial conductor sizes
This table will probably not come out well but it does a comparison similar to the above.
Imperial
Metric
Imperial size
strands / thousandths
Csa of Imperial Conductor
Csa of Metric Conductor
CCC 14[SUP]th[/SUP] Edition 1966
Clipped direct
Close protection, 25°C
in
mm[SUP]2[/SUP]
mm[SUP]2[/SUP]
A
1/.044
0.98
3/.029
1.29
20
3/.036
1.94
1.5
25
2.5
7/.029
2.9
29
4.52
40
7/.044
6.45
7/.052
9.4
7/.064
14.5
16
79
19/.044
19.4
82
19/.052
25.5
25
98
19/.064
38.7
35
130
That is very useful .. Especially for someone like me who hasn't been brought up on the old imperial sizes, many thanks.
ImperialMetric
Imperial size
Csa of Imperial ConductorCsa of Metric ConductorCCC 14[SUP]th[/SUP] Edition 1966
Clipped direct
inmm[SUP]2[/SUP]mm[SUP]2[/SUP]A
1/.0440.98116
3/.0291.2920
3/.0361.941.525
2.5
7/.0292.929
7/.0446.45648
7/.0529.41060
7/.06414.51679
19/.04419.482
19/.05225.52598
19/.06438.735130
Thanks very much, this is very helpful to relative newcomers like myself..
With tin?
Yes. Almost all imperial sizes of copper cable were tinned as standard, instead of being plain copper, and because it was so widespread almost all 'silver' coloured T+E found in the UK is copper. Aluminium was so rarely used that I am struggling to find any samples for the museum. It was more prevalent in the USA, although even there only for a few years at the end of the 60s and beginning of the 70s.
Al cables have a different sheen and feel to tinned copper - greyish rather than bright - and very soft. In a torch flame, the end of a small aluminium cable will soften and bend under its own weight while copper will glow red hot without giving way.
not micrometer digital vernier calipers are your best bet.
you can get a cheap set for around ÂŁ15 at halfords but dont expect them to be super accurate (i did measure 3.5mm pins etc and they were reasonably accurate the biggest problem is there plastic)
just spotted these and there a good buy, do metric and imperial
[ElectriciansForums.net] CCC of old stranded wires
I got a job in Swansea where I know there is at least 1mm equivalent Ali cable, stripped a bit out last year but still some in service. If I go back its yours
Ordered a digital micrometer off ebay now, accurate to 0.001mm. Should be enough! Cost ÂŁ25 delivered. Used to use these in my engineering days. (Not digital then though, calculators were just becoming big news! )
I think for this kind of measure you really need a micrometer to distinguish between such fine strands..
Reply to CCC of old stranded wires in the UK Electrical Forum area at ElectriciansForums.net
Its down to the budget and your experience level - If they cannot pay you cannot work, If you dont know whats safest you shouldn't work - If you...
