Cctv distribution to tvs | on ElectriciansForums
Discuss Cctv distribution to tvs in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
South Wales
Hi,
I have been asked to distribute a Cctv system to multiple TVs in a customer property.
What modulator would be best to do this as there are eight TVs in the property.
Any recomerecommend will be appreciated as it's not a regular task for myself.
I believe you can now get DVB rf modulators. If all the TVs recieve a freeview signal from one aerial disttobution amp, you shoild be able to feed the modulator in to the amp and the CCTV feed can be picked up as a freeview channel.
Edision HDMI Modulator Full HD Distribution over Coax https://www.amazon.co.uk/dp/B00KBXKJ2A/ref=cm_sw_r_cp_apa_i_7MHVCb7CE2RCS
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Reply to Cctv distribution to tvs in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
This is the point of having a trainee badge... it allows you to ask simple questions without the critism reserved for have-a-go heroes. Things...
