Ccu | on ElectriciansForums
Discuss Ccu in the Australia area at ElectriciansForums.net
B
blenki
Hi , quick simple question, are you ok to put the cooker connection unit directly behind the cooker.TA
If you put it directly behind the cooker,how do you isolate it.You would have to pull the cooker out:eek:Or are you talking about the cooker outlet plate
Reply to Ccu in the Australia area at ElectriciansForums.net
I actually did it with a 4 core 4.0mm swa last week!
Great, then I am a bit bemused why you posted your original question. You need to stop doing any work that you cannot properly test, safety is...
