CE or BS? | on ElectriciansForums
  • Thread starter CRAIGNEWHAM
  • Start date
  • Replies 2
  • Views 2K
Discuss CE or BS? in the Talk Electrician area at ElectriciansForums.net
C
CRAIGNEWHAM
Afternoon,
Does anyone know is a light fitting with a CE logo on it is the equivalent of having a BS number on it?
i.e BS EN 60598?
No, it isnt.
CE marked means it conforms to European directives, but that does not necessarily mean it is equivalent to any BS standard.
There are also many products stamped with CE that have not been certified, mainly from China.
If it is a reputable seller, then it may well be suitable for use here, but it is up to the Installer/designer to make sure it is good enough to use to comply with BS7671 if used in an electrical install.
What is CE Marking (CE mark)?
I have about 4 light fittings from B&Q, none of which have a BS number, couple have CE markings. Can I assume these are up to BS standards if they are from a reputable firm like these?
Craig
Reply to CE or BS? in the Talk Electrician area at ElectriciansForums.net
Correction on checking exchange rate: the EVS 3-user copy is 3.8 times cheaper than the BSI "member's half price" single-user copy.
Changed the thread title to Software for electrical / solar photovoltaic systems design which should attract the right people.
