Ceiling fan wiring, power from switch | on ElectriciansForums
Discuss Ceiling fan wiring, power from switch in the UK Electrical Forum area at ElectriciansForums.net
Matthew E
Phoenix
Installed a new ceiling fan, with no previous light or power. There is a switch in the room that controls an outlet. I am trying to draw power from that switch to install another switch that controls the fan (+fan light, just 1 switch for both). Before I do the wiring, just want to make sure I have it right. The dotted lines are the ones I'm planning on installing. I'll be changing the single gang box, to a double gang. The grey colored line is White/Neutral. Brown = Copper/Ground.
Any advice would be helpful. I can provide more information if needed. Standard 120V, 15AMP, 14 gauge wire. I connected the 14-2 cable to the ceiling wire per Home Depot and product instructions, up through the attic, and then down the wall to the switch.
Thanks!
[ElectriciansForums.net] Ceiling fan wiring, power from switch
Reply to Ceiling fan wiring, power from switch in the UK Electrical Forum area at ElectriciansForums.net
It would normally be the outer terminals where the flex of the pendant drop connect.
I have three 6" LED wafers and a ceiling fan on the same circuit/switch. I wanted to control them separately, so I installed GOVEE smart lights...
