Ceiling Joists | on ElectriciansForums
Discuss Ceiling Joists in the Australia area at ElectriciansForums.net
A good way to find a starting place is just knock on the ceiling with your knuckles. You will hear a dull thud where there is a joist, and a more resonant sound where there's a gap. This method is not 100% though! You could try a stud finder, but I've never used one that worked that well.
Reply to Ceiling Joists in the Australia area at ElectriciansForums.net
I would use the Switch & Load 16A - https://www.quickwire.co.uk/product/switch-load-16a/ Designed to do the same thing as the ceiling rose in...
Hi, want to installed some LED strips in the ceiling and wanted to know how the recessed LED profile is fixed in place and stop the plasterboard...
