Ceiling mounted extract fan | on ElectriciansForums
Discuss Ceiling mounted extract fan in the UK Electrical Forum area at ElectriciansForums.net
Plymouth
Hi.
Not had much to do with domestic and subsequently have not fitted many bathroom fans.
Have builders in doing my loft conversion and am wiring myself. Now the only place for the extractor fan is in the ceiling with duct run through void out soffit.
Unfortunately I only just had enough height in loft for conversion so the ceiling void between joists is about 5".
Is there a slim enough fan to mount in the ceiling for this?
Looking around online and no one gives the depth each fans goes back into the wall or ceiling as appropriate .
Pictures look like they go back about 4".
You may have to fit a surface mounted fan with so little space, possibly a centrifugal fan to allow for extract distance
It seems to me even if a flush fan was able to mount, the ducting connection for the change of direction could make it a no go
Thankyou for your answers.
Lankywill: definitely will be visiting wholesalers with tape measure next time I'm nearby. Will look into the models you mentioned.
Des: did expect I'd would need more of a surface fan than flush due to duct connection although haven't looked at wholly surface ones yet.
Thanks for advice on centrifugal. Duct is about 2.5m.
Andy: would love to unfortunately it's a full width dormer on the back and bathroom is under the flat roof.
Any recommendations for a surface ceiling mount fan?
I've fitted about 500+ Vortice Quadro Micro 100/T. These fans are surface mounted and look pretty decent compared to other models. Never had an issue with them either, they have humidistat models also but aren't cheap.
Reply to Ceiling mounted extract fan in the UK Electrical Forum area at ElectriciansForums.net
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
