Ceiling Rose/Pendant Wire Drop to bulb holder... | on ElectriciansForums
Discuss Ceiling Rose/Pendant Wire Drop to bulb holder... in the UK Electrical Forum area at ElectriciansForums.net
J
jimjamyaha
Hi,
I need to replace some ceiling rose/pendants in my property as they've become brittle with age.
I've bought some new ones but they are all the standard length of cable.
If I was to wire in a replacement length is there any standard/requirements to look for... i.e. high temperature (such as Heat Resistant Flexible Cable 3092Y 2-Core 0.75mm² x 10m White | Flexible Cables | Screwfix.com)
or would cable such as this also be suitable:
Round Flexible Cable 2182Y 2-Core 0.75mm² x 10m White | Flexible Cables | Screwfix.com
or
Toolstation > Electrical > Cable > 2 Core Round Flex (2182Y)
Thanks,
James.
don't matter. any heat damage from the lamps generally affects the ends at the lamp holder terminations long before the sheath. as it's your own house, though, go for the HR.
Reply to Ceiling Rose/Pendant Wire Drop to bulb holder... in the UK Electrical Forum area at ElectriciansForums.net
