C
col_bol
Hi, looking for a little guidance on the correct wiring of a ceiling rose. If anyone can help, then all suggestions greatly received.
Description of the current set up is;
1. Landing Light, with two switches. One switch on the stairs and one on the landing (both single switches)
2. The cabling coming from the ceiling is;
a) live (red sleeve)
b) Earth (Green Sleeve)
c) Single Grey sleeved wire (no tape or markings)
d) Single Grey sleeved Wire (no tape or markings)
3. The rose has normal block set up which is
a) two live blocks (one live red wire in there already goes to actual pendant)
b) three loop blocks in middle (currently empty)
c) three neutral blocks (one neutral wire in there already connected to pendant)
d) earth connection
I hope this explains the current hardware.
I thought I knew the correct wiring setup for this, but this didn't work at all.
Can anyone help with advice on the correct wiring setup?
Colin :bulb2:
d) earth connection
Colin :bulb2:
