Ceiling spot halogen dismounting | on ElectriciansForums
Discuss Ceiling spot halogen dismounting in the UK Electrical Forum area at ElectriciansForums.net
J
John Bepkus
Hi,
my friend has in his bathroom 12v halogen ceiling lamps. They got springs which hold fixture in place. I have no idea how to lift them up and dismount fixture without damaging ceiling.
Any idea?
Kind regards John
its a case of due care and attention here i`m afraid.....i know the feeling when they just dont want to budge..lol......what i find is that if you wirk one side away from the ceiling first.....enough so you can get your fingers behind the tophat....then steadily go for the other side....just tease it out gently....as soon as you can get it out far enough to compress the springs......then it should come out ok....nice and steady here though....
Hi,
main reason to dismount this spot light is poor contact in their sockets - from 5 spots only 1 working. That fixture has glass lid - if is necessary to replace bulb i only have to turn it. Inside is only metal strip in U shape which has bulb socket on top. This socket looks really cheap and poor. Any idea how to improve it?
generally the transformers will be close to each fitting. you can get replacement 12volt connectors or replace the lot with 240v fittings. if you go down the 240v route, i would advise getting a qualified sparks to do the job.
Reply to Ceiling spot halogen dismounting in the UK Electrical Forum area at ElectriciansForums.net
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
K
Advice needed - questions before getting new bathroom fitted Hi all, hope this is okay to post. Just over a year ago, I took on my dad's old...
KamikazeBob
K
