central heating fed from spur | on ElectriciansForums
Discuss central heating fed from spur in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
BES
bit of advice please guys. when doing a pir or cu change do you test the central heating wiring which is fed from a fcu off a ring or radial circuit.
thanks neil.
Reply to central heating fed from spur in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
glad it was such a simple fix..... And good job the previous owners didnt take it with them
T
Indirect (Boiler Fed) Megaflo Doesn't Stop Heating Hi, I noticed yesterday that when my HW is on, that the boiler runs constantly... I even...
techweb
T
