central test unit | on ElectriciansForums
Discuss central test unit in the UK Electrical Forum area at ElectriciansForums.net
The CTU will interrupt the permanent line supply to the emergency lights. So you take your supply to the CTU and then on to the lights.
Depending whether they are maintained or not will determine if you need a switched supply.
  • DCTU Garo.pdf
Reply to central test unit in the UK Electrical Forum area at ElectriciansForums.net
Used loads of them, but usually the Hager units. (Although these aren't in a steel enclosure as they are not designed for the UK market.) Any of...
J
Power Flushing Central Heating Hi, I have an old 3 story property with radiators on each floor. The radiators have become increasingly less...
JBASport
J
